Author Topic: Douglas 23/4hp wheels  (Read 1400 times)
Offline John T
« on: 11 Dec 2019 at 20:48 »
Hi I have a Douglas 2 3/4hp 1920. Does anyone know what size wheels it should have so I can look into getting some made.
John
Offline RockDr.
Re: Douglas 23/4hp wheels
« Reply #1 on: 11 Dec 2019 at 21:24 »
Hi John, is it a TS or CW? Most probably you will need 26" rims. You can obtain from Vintage Rims in QLD Australia.
Offline John T
« Reply #2 on: 12 Dec 2019 at 15:53 »
hi thank you i belive its a ts....its a flat tank belt drive...ive just obtained it to restor....any help and info i will be gratefull off..
Offline DJS
« Reply #3 on: 12 Dec 2019 at 16:47 »
A little closer to Burntwood I believe that you can get new beaded edge rims from Richards Bros in South Wales - www.richards-bros.com.
Offline John T
« Reply #4 on: 12 Dec 2019 at 17:31 »
thanks for that info....dont suppose you no wat size thay are..
Offline DJS
« Reply #5 on: 12 Dec 2019 at 18:24 »
Hi again John,
I have a 1924 SW24 which is basically a TS with a flywheel clutch and Kickstarter.
It has 26 x 2 1/2 beaded edge tyres on 26 x 2 1/4 rims.
Hope this helps.
David
Offline John T
« Reply #6 on: 12 Dec 2019 at 18:36 »
hi there i hope so as im losing the will with looking for parts and wheels....
Offline DJS
« Reply #7 on: 12 Dec 2019 at 21:48 »
What other parts are you looking for?
If you’re a member of the LDMCC have you approached the Spares Secretary re: your needs?
« Reply #8 on: 12 Dec 2019 at 21:56 »
Keep your spirits up John!
Wheels can be fun, and you can do them yourself if you want to. Of course you can get someone to build them for you, but this is (a) expensive and (b) no fun at all. Happy to walk you through it if you decide to build them yourself.
Have you got hubs?
Offline John T
« Reply #9 on: 13 Dec 2019 at 17:48 »
everything....ive got a frame tank engine,,,,o and handelbars
Offline DJS
« Reply #10 on: 14 Dec 2019 at 09:40 »
As a starter for ten I’d have a look at Bert Pol’s website. He has a number of remanufactured items for 2 3/4s.
Hope this helps.
David
