Author Topic: 1954 Douglas MK5 that just won't start  (Read 422 times)
Offline lovejoy
« on: 03 Dec 2019 at 19:09 »
Hi All,
I have a 1954 Douglas MK5 that just won't start.
It was running ok 12 months ago. I have checked everything. It has sparks, not brilliant but there are sparks. Carbs are clean and seem ok, new fuel, compression is down a bit on the right side. I have checked the timing from the Douglas book.
It is not even trying to fire.
Any ideas please? Is there something obvious I am missing?
Thanks in advance
Martin
Re: 1954 Douglas MK5 that just won't start
« Reply #1 on: 03 Dec 2019 at 19:59 »
Cobwebs? I know it sounds terribly old fashioned, but when my bikes won't start I push them down a hill!
Have fun,
« Reply #2 on: 03 Dec 2019 at 20:57 »
Try starting it with the points cover removed. If it starts, check out the cutout button - most of them have a grub screw securing the cable - these can work loose and short out to the handlebars.
Offline phil1
« Reply #3 on: 08 Dec 2019 at 13:36 »
Hi Martin Re no start can you flood both carbs with tickler? that is a must, have good spark at clean dry plugs, if you have open throttle 1/4 then should start like the clappers. Regards Phil.
