Author Topic: Timing Gears.  (Read 2194 times)
Offline phil1
Timing Gears.
« on: 25 Nov 2019 at 18:46 »
Hi Friends I would just like to know where these timing gears came from! I have an identical pair taken from a MK engine,and  can  see that they are wasted in the centre and therefore very much lighter in weight than others I have seen. Many thanks.  Phil1ftp://.
Re: Timing Gears.
« Reply #1 on: 25 Nov 2019 at 19:11 »
Hi Phil,
            They are probably from a wartime Douglas Generator engine.
Offline phil1
Re: Timing Gears.
« Reply #2 on: 27 Nov 2019 at 08:02 »
Hi Eddie thanks for your reply re pre war timing gears. My next thought is as they look in pretty good shape and considerably lighter, bit like pre unit (Triumph) I would like to use them in the MKV. Regards Phil.
Re: Timing Gears.
« Reply #3 on: 27 Nov 2019 at 08:20 »
Phil,
       I have heard of owners using them in Mark series engines, but I would suggest you compare them carefully with a set of genuine Mark camwheels - the timing marks may not be in the same position relative to the keyway! I know for a fact that the crankshaft gear looks the same as that on a Mark, but one has the keyway in line with a tooth and the other has the keyway between 2 teeth. There are, however, advantages to using these gears - being from a generator engine produced under a government contract, the materials used were to a higher spec than those used in the motorcycle engine.
