Author Topic: 1926 Douglas EW350 Wheel Offset  (Read 875 times)
Offline SteveTea
« on: 23 Nov 2019 at 17:47 »
I need to get the rear wheel of this bike rebuilt after it was stripped down to have a new sprocket fitted to the hub.  Unfortunately no one thought to measure the offset before it was dismantled.  I have seen one post on here that implies there is zero offset, can anyone confirm or deny this please?
Offline EW-Ron
Re: 1926 Douglas EW350 Wheel Offset
« Reply #1 on: 15 Jan 2020 at 22:43 »
I have a stray 26 EW wheel or 2, just eyeballing them they look to have zero offset,
the rims looks centralized between the flanges.
Although I don't know precisely how folks would measure any offset, if it was only a small measurement ?
Offline Charlie18
« Reply #2 on: 16 Jan 2020 at 08:51 »
Hi SteveTea. I will attach some photos of a spoked on brakedrum EW rear wheel to this post .  I ran a string line from the valve hole to as near as possible to centre on the opposite side of the rim.   I then measured both sides out from the string  to get approximately 7 mm offset . The brake drum is the larger figure .  Laying the drum flat on the bench it measured 57 mm from the side of rim  to the bench.  Just happens that Iím looking at respoking my rims soon.   Cheers
« Last Edit: 11 Feb 2021 at 19:27 by Dave »
Offline Charlie18
« Reply #3 on: 16 Jan 2020 at 09:02 »
Might be a bit easier to read .
« Last Edit: 11 Feb 2021 at 19:28 by Dave »
Offline EW-Ron
« Reply #4 on: 17 Jan 2020 at 05:57 »
Interesting. I must compare measurements and methods.
