For Douglas enthusiasts worldwide since 2004
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Help
Search
Login
Register
Douglasmotorcycles.net
Reference
Douglas Motorcycle Technical Articles
gearbox MK1
« previous
next »
Print
Pages:
1
Author
Topic: gearbox MK1 (Read 6521 times)
gmh
Member
gearbox MK1
on:
16 Nov 2019 at 09:50 »
Hello from Slovenia!
I bought a Douglas 1948 mark1 (
https://www.douglasmotorcycles.net/index.php?topic=1035.0
The engine is now runing ok but in the midle of testig it jump in gear and block it.
I disassemble gearbox and there is no parts broken or damiged. Only problem i found is this on video.
https://youtu.be/AlnvBUQ0_Oo
Sory for my english.
Write slow i cant read fast.
Logged
Neville Heath
Full Member
Re: gearbox MK1
Reply #1 on:
17 Nov 2019 at 14:46 »
Hi there in Slavenia. I think the brass bush has moved on the shaft towards the gearbox.
Neville Heath
Attachments converted to linked images - Dave, 07Feb2021
Last Edit: 07 Feb 2021 at 07:19 by Dave
Logged
Neville Heath
Full Member
Re: gearbox MK1
Reply #2 on:
17 Nov 2019 at 14:54 »
My photo shows where the bush should be. If it is too far forward it would foul the inside of the input part.
Neville
Logged
gmh
Member
Re: gearbox MK1
Reply #3 on:
17 Nov 2019 at 17:41 »
Thank you Neville
You are the best! This is right foto .
Wellcome to
https://en.wikipedia.org/wiki/Slovenia
(not Slavenija)
Gregor M. Humar
Logged
gmh
Member
Re: gearbox MK1
Reply #4 on:
17 Nov 2019 at 18:25 »
Problem is located.
Oil hole is blocked and no channels.
Thanks!
Logged
Eric S
Senior Member
Re: gearbox MK1
Reply #5 on:
17 Nov 2019 at 21:26 »
Hello you (?)
It looks like somebody made a sleeve of brass without all the channels but on your video the teeth do not seems to fall in front of notches. Can't you rotate the shaft around?
Eric
Logged
gmh
Member
Re: gearbox MK1
Reply #6 on:
06 Mar 2020 at 19:10 »
new part is made
Gregor
Logged
Print
Pages:
1
« previous
next »
Reference
gearbox MK1
