For Douglas motorcycle enthusiasts worldwide
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Help
Search
Login
Register
Douglasmotorcycles.net
General
Douglas Motorcycles - General Discussion
Mk5 clutch actuation
« previous
next »
Print
Pages:
1
Author
Topic: Mk5 clutch actuation (Read 3441 times)
dalgrae
Full Member
on:
06 Nov 2019 at 11:44 »
Hi I need the 3 small hardened rollers that are on the clutch actuation mechanism for my Mk5 ref plate 14 ,can I use silver steel suitably machined and then hardened and tempered.
Any advice most welcome
Colin
Logged
phil1
Full Member
Re: Mk5 clutch actuation
Reply #1 on:
06 Nov 2019 at 13:40 »
Hi Colin have had my MkV stripped to the last nut and bolt and I would do as you say, use silver steel to re make those rollers part no 11222, if you have the dimensions ? I could help if needed. Cheers Phil.
Logged
dalgrae
Full Member
Reply #2 on:
06 Nov 2019 at 14:11 »
Hi thanks for the reply and the offer,I have some existing rollers but with lots of wear on the bores so I am Ok for the sizes it was the material I needed advice on
Regards. Colin
Logged
robertolander
Member
Reply #3 on:
17 Nov 2019 at 14:55 »
Colin: If you can locate a piece of chain that has the inside of the rollers at 6mm these will do wonderfylly! regards Jumbo
Logged
douglas1947
Master Member
Reply #4 on:
17 Nov 2019 at 16:08 »
Colin,
I used the rollers of a 3/8 x 1/4" chain for replacing these rollers.
Logged
Print
Pages:
1
« previous
next »
General
