Author Topic: File images not displaying  (Read 4655 times)
Offline TonyC
« on: 05 Nov 2019 at 12:48 »
When looking back at previous posts I am finding that some of the images are not able to viewed anymore. All I see is a border from where the image used to be. If you click on it, it just makes it smaller. Is there any way of solving this?
Tony
Re: File images not displaying
« Reply #1 on: 05 Nov 2019 at 17:03 »
Tony,
This is due to the addition of an SSL (Secure Socket Layer) certificate to the domain a while back. There is a general push from HTTP addresses to more secure HTTPS by the industry to squeeze out the bad guys. The certificate verifies that you are going to a registered site and not being redirected to another, potentially unsecured - or worse - malware site.
Any hyperlink (invariably an image, for our purposes) in a post that had a HTTP address may not work. In the case of an image, it will display a blank frame as you described. There was a  plug-in installed to the forum software that was supposed to proxy these old addresses to the new HTTPS syntax, but it does not always work. Sometimes it only works for some of the images in a post, sometimes after you make an edit elsewhere in the post they suddenly reappear, and sometime they just don't.
One of the Forum maintenance tasks is to do an en-mass replacement of all the occurrences of HTTP in the database with HTTPS. Given the number of posts now in the database with pictures it is a big operation and not without risk. There has been some satisfactory testing on a replica, off-line copy of the site, but the problem at the moment is that running the same process on the actual site on the host server much slower and time-out errors has been an issue.
In the meantime when I have come across those occurrences of images not displaying in older posts, as Moderator I have been editing the post and replacing "HTTP" with "HTTPS" in the image address. Members can also edit their own posts to fix/update broken links. Any post created from about May 2017 onward already has the more secure HTTPS syntax in use.
Offline Dave
« Reply #2 on: 05 Nov 2019 at 18:26 »
Tony,
If there are some images you would like to see, please go to that topic, copy the URL from the browser address bar and post it here.
For example, if you look up at the address bar in your browser now, you will see a URL that begins with something similar to the line below:
https://www.douglasmotorcycles.net/index.php?topic=7676.0
Just highlight the whole line, right click and choose copy. Then return to your post here, right click and choose paste.
Alternatively, all we need is the topic number. In the example above, this is 7676. Just post this number.
We can then fix that topic so the images display properly.
Offline TonyC
« Reply #3 on: 05 Nov 2019 at 21:59 »
Hi Doug and Dave,
Thanks for the reply, it makes total sense!
I have found an advert for the Fairy in one of dads files and wanted to check to see if it had already been posted hence the request.
Best regards
Tony
