Author Topic: Crank Pinion Screw, 1936 Aero  (Read 7820 times)
Offline A31ndrew
« on: 18 Oct 2019 at 23:41 »
I need to remove the slotted screw which secures the crankshaft pinion on a 500 Aero. Before I start applying force, can anyone advise whether the screw has a right- or left-hand thread? Any tips welcome; the slot looks quite delicate and could easily become damaged.
[Attachments converted to linked images. 25Nov21 -Doug]
« Last Edit: 27 Nov 2021 at 01:54 by Doug »
Offline Eric S
Re: Crank Pinion Screw, 1936 Aero
« Reply #1 on: 20 Oct 2019 at 18:15 »
I don't have the parts with me but I am pretty sure I did not had any LH thread when I disassembled them.
Offline A31ndrew
« Reply #2 on: 20 Oct 2019 at 19:50 »
Thanks, Eric. Since posting, I have removed the screw plug, which had a left hand thread, and the crank dog/nut which has a right hand thread. Both were extremely tight and I had to make a box key to remove the nut.
Offline Eric S
« Reply #3 on: 20 Oct 2019 at 22:27 »
Sounds interesting. I don' t remember having seen such a left hand nut.
I am picking up honed cylinders and pistons with new rings tomorrow so hopefully I can work on reassembling later this week...
Offline Eric S
« Reply #4 on: 21 Oct 2019 at 19:05 »
Got my crankshaft back today, it's sure is RH thread.
« Reply #5 on: 22 Oct 2019 at 02:31 »
Eric,
It is the difference between the 1936 crankshaft, which does not reach out to the timing cover and have a supporting bush, and the c1937-38 ones that do.
Offline Eric S
« Reply #6 on: 22 Oct 2019 at 12:49 »
got you. That is why I was not understanding the picture Andrew posted. This did not seems familiar to me...
I already forgot how it was assembled. And I need to reassemble the whole beast...
