Author Topic: Dragonfly main stand pivot bolt spacer  (Read 2851 times)
Offline Sgtbiro
« on: 03 Oct 2019 at 19:19 »
Hi all, can someone supply me with the dimensions for a Dragonfly near side main stand pivot bolt spacer, part No 34287 please.
Cheers Kevin..
Offline cbranni
Re: Dragonfly main stand pivot bolt spacer
« Reply #1 on: 07 Oct 2019 at 16:36 »
I will check the sizes tomorrow Kevin.
Colin
Offline Bynorthsea
« Reply #2 on: 07 Oct 2019 at 18:25 »
These are the dimensions I was given, they work ok
Offline cbranni
« Reply #3 on: 08 Oct 2019 at 16:30 »
Hi Kevin
The spacer I made which looked right was i.000"od x .690" id x .250" width, hope this helps.
Colin
Offline Sgtbiro
« Reply #4 on: 08 Oct 2019 at 18:58 »
Thanks for the help
Cheers Kevin.
Offline Sgtbiro
« Reply #5 on: 08 Oct 2019 at 19:00 »
Hi Kevin
Colin
That`s brilliant Colin thanks very much.
Cheers Kevin..
