Michael,
Unlike the standard road models, the Comp and the Plus models both had rear brake drums with bolt on sprockets. There is a difference between the drums used on the Plus and the Comp - the Comp has the flange for the sprocket closer to the outside of the drum, so that the chain will clear the wider trials tyre. From memory, the difference is about 6.5mm (I used a Plus drum for a while until the correct drum became available).
