So for 1936, the carb should be a 74/027, which is probably identical to a 4/027 except alloy rather than brass.
The part number for the correct complete float chamber is 62/079. This is the "standard" "small float chamber" "bottom feed".
The bare fuel bowl for the 62/079 is the 62/025s, but I guess you have the 22/028s which is the same bowl, but top feed. Drawing attached.
