Author Topic: Petrol tank screws for 2 3/4hp. Whitworth 7/32 x 24 tpi.  (Read 832 times)
Offline lovejoy
Hi All, Does anyone know where I can get Screws for suspending tank from the frame. They are Whitworth 7/32 x 24 tpi. (90 degree Raised Countersunk Head Screws)
Any information would be helpful.
Regards Martin
Offline GlenDouglas
Re: Petrol tank screws for 2 3/4hp. Whitworth 7/32 x 24 tpi.
« Reply #1 on: 09 Sep 2019 at 20:29 »
Hi not sure if the Douglas club have any. If you need temporary screws, Drum Tension Rod 7/32 25mm long 10 Pieces on ebay work real well.
Regards Glen
« Reply #2 on: 09 Sep 2019 at 21:38 »
Martin,
I have these in heat treated stainless steel at $3 each. Though if the LDMCC has them, likely it will be cheaper from them. They were also used on the small DT airbox, which is what I make them for.
