Author Topic: S6 crankcase pressure venting  (Read 622 times)
Offline Kalle
« on: 14 Aug 2019 at 12:31 »
Hi
Does anyone on the forum know, have a ventilation disk or drawing for a S6 1930 according to photo. (photo from Ian Dabney)
Kalle
Offline Bert
Re: S6 crankcase pressure venting
« Reply #1 on: 07 Sep 2019 at 04:08 »
Hello Kalle,
I found a drawing that I made from my very worn breather disc and estimated the dimensions from that. Also attached are some photos. Note that there is a ring around the disc with mesh wire holes in it - you can just see it in the photo of the assembled engine. You will have to make a bronze bush to suit the size of your shaft and press it in.
Good luck.
Bert
Offline Bert
« Reply #2 on: 09 Sep 2019 at 00:15 »
o
