Support & How to Join
Side Panel Notices
Today at 01:04:34
Welcome to the new site!
T 35 oil pressure
Started by CooperS, 03 Aug 2019 at 20:43
CooperS
I am nearing completion of my 1947 Mk1 and would like to monitor the oil pressure when I first start the engine. Any suggestions?
Thanks.
eddie
There is a blanking screw in the bottom of the vertical oilway in the front crankcase half (originally a cheese head screw with a screwdriver slot). You could replace it with a connector to an oil pressure gauge. You'll only need a gauge that reads up to about 20 psi - I doubt that the pressure will go that high - Mr Douglas reckoned about 6 - 9 lbs psi for the Mark series on a warm engine..
CooperS
Thanks I will check it out
