Author Topic: Valve sprting Cover 1930 Douglas 350cc  (Read 2320 times)
Offline douglas1947
« on: 24 Jun 2019 at 16:51 »
I would like to finish my 1930 Douglas 350cc H3.
with the dismantled engine came 2 different valve spring covers.
I think the "grit" one is the right type, the cosed cover a more early type?
the "grit" one fits only on front cylinder.
I would like to get more informations and help.
Offline douglas1947
Re: Valve sprting Cover 1930 Douglas 350cc
« Reply #1 on: 26 Jun 2019 at 17:14 »
sorry for the mistake in the "Subject"!
Valve Spring Cover
The engine No is ER812.
The covers are similar to B29 and on?
The closed type may be EW?
« Reply #2 on: 26 Jun 2019 at 20:11 »
Michael,
The 350cc models through 1929 had 'solid' tappet covers. Starting with the 1930 350cc models, the covers had the ventilation slots.
Offline douglas1947
« Reply #3 on: 27 Jun 2019 at 16:19 »
Doug,
thanks for the information!
It seems so, the rear cover has a different shape (like the one without the slots, with double bow)?
Has someone an idea; may be I can do an alloy cast reproduction.
A friend is artist for scultures and do alloy + bronce casting.
« Reply #4 on: 30 Jun 2019 at 15:33 »
Years ago the LDMCC Spare Department had these as unfinished castings. Don't know if they still offer them, but someone might have a unused set under the workbench.
« Last Edit: 01 Jul 2019 at 18:05 by Doug »
Offline douglas1947
« Reply #5 on: 03 Jul 2019 at 18:59 »
Hi Doug,
that sounds interesting.
Do you think I should try to ask under "wanted"?
