Author Topic: Cracked S6/T6 Crankcases. Common Problem?  (Read 455 times)
Offline PaulW
« on: 14 May 2019 at 06:54 »
OK, so two of our bikes have cracked crankcases, in exactly the same position.  One has been repaired, the other has not.  Is this a common problem / weakness?
« Last Edit: 16 Jul 2019 at 08:10 by PaulW »
Re: Cracked S6/T6 Crankcases. Common Problem?
« Reply #1 on: 14 May 2019 at 22:05 »
I don't recall others reporting a fracture there (or seeing same before), though two with the same issue does suggest a trend. If it is holding fast, perhaps not wake a sleeping dog. Douglas aluminum can be truly awful to weld due to porosity and impurities. You will have to re-skim all the joints to true it up, and sleeve and bore the bearing journal round as that amount of welding is sure to distort it. Not a minor undertaking!
