Author Topic: Barrel identification  (Read 2818 times)
Offline BernardsE31
« on: 14 Mar 2019 at 12:59 »
have a pair of barrels and believe the should suitable for a 30s models.
Bore is quit large with around 75mm.
Location of ports are oposite aand not as for S6/T6 models.
Its not Mastiff as well.
Any idea?
[Attachments converted to linked images. 29Nov21 -Doug, Admin]
« Last Edit: 29 Nov 2021 at 16:48 by Doug »
Re: Barrel identification
« Reply #1 on: 14 Mar 2019 at 15:01 »
The shape is as for the 1936-38 500/600cc Aero models. However those were not offered as a 750cc to the best of my knowledge. Just 60 and 68mm bores (68mm stroke).
Correction, Aero models & stroke: 68 x 68 and 74 x 68.
« Last Edit: 14 Mar 2019 at 16:34 by Doug »
« Reply #2 on: 14 Mar 2019 at 16:22 »
They could be 'Aero' as the spec sheet for the DC/38 model lists the bore size as 74mm.
« Reply #3 on: 14 Mar 2019 at 16:35 »
Oops, my mistake. I was looking at the bore figures for the earlier 82mm stroke engines. The 500 and 600cc Aeros were 68 x 68 and 74 x 68 respectively. Previous post updated.
Offline BernardsE31
« Reply #4 on: 14 Mar 2019 at 17:05 »
Thanks for quick comments.
It make sense for a late Aero 600 with shorter stroke and big bore.
Heads looks also quit "modern" - they dont have the cooling plugs.
Thanks Bernd
« Reply #5 on: 14 Mar 2019 at 20:18 »
Not checking dimensions but they looks exactly like the cylinders on my Aero?
« Reply #6 on: 15 Mar 2019 at 06:26 »
Views of a 600cc Aero (and cylinders).
Offline BernardsE31
« Reply #7 on: 15 Mar 2019 at 09:25 »
Thanks for pictures.
My barrels looks exactly the same - 36...38 Aero I learned.
Front barrel has an union for oil?
Rear barrel not.
Bernd
« Last Edit: 29 Nov 2021 at 16:51 by Doug »
« Reply #8 on: 15 Mar 2019 at 13:49 »
Bernd,
The union is to vent oil mist from the front tappet chest over (via a aluminum tube) to the primary chain case. You can just see this tube in the photo previously where it emerges from behind the oil lines and intake manifold.
