Author Topic: Belt Rim Retaining Bolts - Pack of 10  (Read 2209 times)
Offline pvn06
« on: 27 Feb 2019 at 18:24 »
Hi all,
While recently restoring my Douglas 2 3/4hp rear wheel (not a simple task as I am sure many of you already know!), I was trying to decide the best way to retain the original Douglas Belt rim to the spokes.  I know that originally a small plate was used, with two screws, one either side of the spoke.  My belt rim had two small holes for this purpose.  However, while searching the web on the subject, I read an article of someone who had thought up a similar solution to this for his own belt drive wheel.  It looked a good idea - so I thought it worth having a go for my bike.
These are small stainless steel fasteners, with a cylinder head cross drilled so they can feed through a 12 gauge spoke.  on one end of the cylinder is a 2 BA threaded shaft that retains the belt rim. on the other side the cylinder is bored and threaded to take small stainless steel hex head grub screws.
Feed each retaining bolt onto the relevent spokes before starting the wheel building process, then once the wheel has been laced to the rim, the belt rim can be fed onto the 2 BA threaded ends and the nuts loosely placed.  Then the belt rim can be centred, before finally tightening up the grub screws.
I found this worked well on the wheel I built - a couple of photos are shown below and on the listing, as well as instructions for use.
As with many other parts - as I had to write the programs to CNC manufacture these for my bike, I dediced to make them commercially in sets of 10 - hope they may be of use to you if you are restoring a belt rim wheel and have similar issue of how to retain it ahead.
If you want to purchase a set of these, ready to fit, then here is the listing on our RacingNorton website:
https://racingnorton.co.uk/epages/4c675e64-813f-4c0a-8926-87a680c962a0.sf/en_GB/?ObjectPath=/Shops/4c675e64-813f-4c0a-8926-87a680c962a0/Products/%220803%20DG234_0015%22
Best wishes
Paul Norman
www.RacingNorton.co.uk
Re: Belt Rim Retaining Bolts - Pack of 10
« Reply #1 on: 28 Feb 2019 at 06:42 »
This looks like a neat solution, but I would be very wary of the grub screws leaving a 'nick' in the side of the spokes - it's almost inviting premature spoke failure!
Offline pvn06
« Reply #2 on: 28 Feb 2019 at 19:21 »
Hi Eddie,
I would hope not . . . but a valid concern.
I am hoping I may have my bike up an running late this year (my estimates on any restoration are notoriously crap though!), so will update this listing If I see any issues (but as I never knowingly sell anything I believe to be unsafe .. . I will have removed from listing myself first!).
All that said, the actual bite onto the spoke does not seem extreme, and neither do I think it needs to be as it is the spokes that hold the radial tension.  But as I say in the listing, think it is is important to use threadlock to avoid the grubscrews loosening
best wishes
Paul
