Author Topic: I am looking for Douglas model EW / L-3 /H-3 flywheel extractor.  (Read 134 times)
Offline yoshimasa negishi
Hello.
It is necessary for overhaul of the engine.
Payment is made at PayPal.
The EW has a collar screwed into the centre of the flywheel, so that fully unscrewing the flywheel nut will draw the flywheel off the crankshaft taper without the use of an extractor.
Hello Eddie
thank you for your reply.
In 1930 model H-3 and L-3, the flywheel extractor was described in the maintenance manual.
Is it possible to remove the flywheel without the flywheel extractor?
Thank you
