Author Topic: Parts required to complete  (Read 760 times)
Offline CooperS
« on: 03 Feb 2019 at 02:24 »
Hi
I am in New Zealand and am about half way through a 1947 T35 rebuild. I have an extensive list of parts required to finish it. If anyone can give me contacts or have any of the following it would be a great help before I start scouring the world on the internet
1.  7/8 dia handlebars
2.  Twin cable twist grip and rubbers for both sides.
3.  Advance and retard lever
4.  Horn switch
5.  Earthing switch
6.  Pair of handlebar levers
7.  Complete headlamp with switch etc
8.  Battery box
9.  Voltage control unit (Lucas MCR1-L31)
10. Bridge clamp for the dynamo with bolts.
11. Kickstart lever 3/4 plain shaft
12. Complete set of rubber parts footrests pedals and tank side rubbers
13. Guard for the final drive sprocket.
14. Rear chain guard
15. Brake pedal (mine has been butchered)
16. Centre stand
17. Tool box any condition.
18. Front and rear mudguards with mounting stays
19. Front seat with springs and rear seat
20. Speedo head complete.
21. Speedo drive at the rear wheel ( actually only need the worm.
Offline Daren W Australia
Re: Parts required to complete
« Reply #1 on: 03 Feb 2019 at 05:02 »
Hi Try Ebay LDMCC and your local classic bike store
1.  7/8 dia handlebars flat bars. Get them on ebay or your local M/C accessory shop.
2.  Twin cable twist grip and rubbers for both sides. Get them on ebay or your local M/C accessory shop it should be a single cable with a splitter under tank.
3.  Advance and retard lever. Get them on ebay or your local M/C accessory shop.
4.  Horn switch. Get them on ebay or your local M/C accessory shop.
5.  Earthing switch. Get them on ebay or your local M/C accessory shop.
6.  Pair of handlebar levers. Get them on ebay or your local M/C accessory shop.
7.  Complete headlamp with switch etc. Get them on ebay or your local M/C accessory shop.
8.  Battery box. LDMCC club spares.
9.  Voltage control unit (Lucas MCR1-L31). Get them on ebay or your local M/C accessory shop
10. Bridge clamp for the dynamo with bolts. LDMCC club spares.
11. Kickstart lever 3/4 plain shaft. I can check my spares send photo is it hollow or solid ?
12. Complete set of rubber parts footrests pedals and tank side rubbers. Get them on ebay or your local M/C accessory shop.
13. Guard for the final drive sprocket. LDMCC club spares.
14. Rear chain guard. LDMCC club spares.
15. Brake pedal (mine has been butchered). LDMCC club spares.
16. Centre stand. LDMCC club spares.
17. Tool box any condition. LDMCC club spares.
18. Front and rear mudguards with mounting stays. Advertise in the LDMCC Magazine.
19. Front seat with springs and rear seat. Front seat from ebay or your local M/C accessory shop.
20. Speedo head complete. 80 mph smiths on ebay
21. Speedo drive at the rear wheel (actually only need the worm). Get them on ebay.
Regards Daren
« Reply #2 on: 03 Feb 2019 at 07:01 »
Just a quick note: Be careful which handlebars you buy - most are too narrow in the centre straight section for the T35's. The usual result is strained and fractured handlebar clamps.
Offline CooperS
« Reply #3 on: 03 Feb 2019 at 21:39 »
Thanks guys for your comments. How do I find out what spares the club has and how do I arrange to buy them?
Offline bear640
« Reply #4 on: 04 Feb 2019 at 02:08 »
PayPal is your friend.
Offline Roys rider
« Reply #6 on: 07 Feb 2019 at 08:06 »
The Club website
https://douglasmcc.co.uk/
Dick is the spares man. you have to join the club to buy spares he can ship to NZ.
Peter
Offline CooperS
« Reply #7 on: 09 Feb 2019 at 21:14 »
Thanks for your help guys. Was looking in vane for a new alloy silencer, decided I would have to weld a new bottom in the old one. Turned out ok
