Author Topic: relining a prewar flywheel clutch  (Read 1413 times)
Offline roger h
« on: 18 Jan 2019 at 14:48 »
I'm looking for someone who can either supply the  parts or offer the service of relining the clutch on a prewar flywheel type Douglas clutch. Any ideas please?
Thanks,
Roger
Cumbria, UK
01229 585244
Re: relining a prewar flywheel clutch
« Reply #1 on: 18 Jan 2019 at 15:59 »
Hi Roger,
if you will find nothing in UK I can find a solution (in Germany).
Offline Andy Smith
« Reply #2 on: 19 Jan 2019 at 10:31 »
Hi Roger
Saftek at chapel-en-le-frith will put a bonded lining on pretty much any surface but there's a firm that re cork plates pop up on facebook now and then but can't find a link if I find it I'll post it. Andy
« Reply #3 on: 19 Jan 2019 at 11:49 »
Roger,
           Which sort of clutch plate have you got? Is it a cork insert plate (S6, etc.) or a 'Ferodo' disc plate? If it is 'Ferodo', Friction Services at Keynsham, Bristol should be able to help out - they used to supply the clutch and brake linings for the LDMCC spares scheme.
Offline Andy Smith
« Reply #4 on: 19 Jan 2019 at 20:08 »
Roger Try the clutchcorkcarvery Andy
