Author Topic: TS project for sale (Now Sold pending payment)  (Read 1090 times)
Offline GlennMckenzie
« on: 16 Jan 2019 at 00:47 »
Not enough time for this one so it has to go. Basically its the leftovers from all my other Douglas projects.
Engine turns over and seems to be ok although it missing cam and push rods.
I do have another complete Engine if you prefer that one. Both Engines are dated 24 ish from memory.
Gearbox is complete and seems to be perfect.
Frame dates to 1922 but needs replacement rear frame fork welding in.
Rear carrier is bent but repairable. Tanks has original paint and seems very solid and usable. I think the Bush fix on top of the Tank adds to the character but could be repaired properly if you wanted to restore it.
Good handlebars and front end. Incorrect front wheel but I have another correct TS Douglas Hub. Both Hubs would need boring out and fitting modern bearings. Needs new rims. I have a complete TS carby on the second engine. Oil pump parts and repairable oil dripper parts included. I also have a brake pedal and maybe some other brake parts.
Should be enough parts here for a complete maggy. Good forks.
Missing a rear stand, rear guard, gear change linkage and handle plus a couple of the front end bearing cups. Also missing Tank Caps.
Make an offer, I had it on Gumtree for a while but go sick of the time wasters.
Cheers Glenn
« Last Edit: 25 Jan 2019 at 09:18 by GlennMckenzie »
Re: TS project for sale
« Reply #1 on: 17 Jan 2019 at 02:47 »
This is the complete Engine
