The baseplate is just 1/16" thick tufnol with the bulbholder and resistor mounted on it. The ignition warning light bulb is a 2.5 volt bulb with the resistor wired in parallel to it - thus dropping the bulb voltage to 2.5 volts, but more importantly, permitting the ignition system to keep working in the event of a bulb failure.
