Author Topic: 1922 2 3/4hp main bearings  (Read 1023 times)
Offline Chris (Sprinter)
« on: 10 Nov 2018 at 17:58 »
Hello all,
Can someone please confirm the main bearing set up on a 1922 2 3/4hp engine?
I believe it should be a 6304 for the timing side and a 4304 for the drive side. Should the drive side be a self-aligning bearing? Is a double row roller preferred to a double row ball bearing?
The engine that I am rebuilding has been mess about such that there is only a single row roller in the drive side crankcase with spacers as appropriate.
Thanks in advance.
Chris
Offline kmd
Re: 1922 2 3/4hp main bearings
« Reply #1 on: 11 Nov 2018 at 13:28 »
Hi Chris
6304  single roller valve gear side
4304  double roller flywheel side
Kev
