Author Topic: Electroless nickel plating  (Read 1501 times)
Offline Bob M
« on: 26 Oct 2018 at 02:43 »
I saw your remarks about hard chroming crankshafts in Erics Aero Douglas thread and wondered whether you had any similar crankshaft experience with electroless nickel plating. I didn't want to go off track from Erics thread so am asking here.
My experience with the process is limited but positive but I would like to know more as the more we know about various processes the more chance we have of keeping our beasties on the road.
Cheers,
Bob
  • Global Moderator
Re: Electroless nickel plating
« Reply #1 on: 26 Oct 2018 at 05:06 »
Bob,
In theory it should avoid the hydrogen embrittlement because it doesn't use electricity right? Well, not so simple. My understanding is both produce hydrogen, but electroless nickle creates less than electroplated nickel. However the main culprit is the acid cleaning/etch step immediately prior to plating, which places far more free hydrogen at the surface of the base metal than the plating does. It comes from the water surrounding the part. It is this hydrogen (atoms) that migrates in amongst the base metal lattice at the surface and subsequently trapped under the plating that leads to the problem. Either way, baking seems to be the remedy.
I see two problems with using electroless nickel to build up parts. The deposition rate is much slower than can be achieved with electroplating, and maybe there is even a limit to the practical thickness. Second, the adhesion is not as good. I have used electroless nickel to barrel plate large quantities of small nuts and screws. I found it very prone to chipping off at the corners of the nuts when a wrench is applied and alongside the screwdriver slots. These were parts done by a commercial plater, who I assume knows the proper way to do it (90% being preparation). Of course, perhaps they botched it, but all the other types of plating work I have had then do is very good (and I have tried many different platers over the last thirty years.) So I don't trust it for applications where there is highly localized pressure.
For building up a journal that is slack where a ball bearing presses on, or a flywheel taper, I suppose it would be o.k., but you would still need to bake the part. For heavy builds (chrome, nickel, or whatever) I understand the recommendation is plate a little, bake, and then plate on the heavy deposit. Hydrogen atoms are cunning little escape artists, but the thicker the overburden of plating, the harder it is to drive them out of the base metal surface. The preliminary plating acts as a barrier to any free hydrogen generated during the subsequent plating.
Offline Bob M
« Reply #2 on: 27 Oct 2018 at 07:03 »
Thanks for that Doug,
I confess to never trying the hard chroming process. Never had the need to so know nothing about it but for one reason or another have had the electroless nickel process pushed under my nose from several directions.
The local practitioner solely does electroless work. They make a point of separating themselves from any sort of electroplating. For whatever reason I don't know. They certainly do a fair amount of decorative nickel plating such as the lower halves of Indian cylinders, fuel lines, carburettors and such like but my budget doesn't allow for costly motorcycles like Indians so I haven't gone down that track. Locally it does seem the easiest way to get vintage style nickel plating done. Nevertheless the decorative stuff seems to be just a sideline from engineering reclamation work.
Cheers, Bob
