Author Topic: 1936 Aero handle bar mounts  (Read 1285 times)
Offline nigeld
« on: 05 Aug 2018 at 05:04 »
1936 Aero 500/600
Hi.. I'm restoring two old Douglas handed to me by my 86 y.o. father here in New Zealand ( he is still alive  :)  ) He disassembled them many years ago  :( and there are a few bits that are missing that I'm hoping someone may be able to help with.
The main parts so far are:
1: The two handle bar assembly mounts from the handle bars to the top of the girder forks.
2: The foot rest parts that go out from the frame and the rubbers attach to.
3: Petrol caps for the tank
4: Girder Fork  Damper Star Washers
Thanks Nigel
« Last Edit: 05 Aug 2018 at 06:54 by nigeld »
Re: 1926 Aero handle bar mounts
« Reply #1 on: 05 Aug 2018 at 06:27 »
Nigel,
         I think you need to confirm which model you have - Aero's were not made in 1926. It could be either a 1926 EW model or a 1936 Aero. They are totally different bikes.
Offline nigeld
Re: 1936 Aero handle bar mounts
« Reply #2 on: 05 Aug 2018 at 06:47 »
Thanks Eddie .. I've edited the post..
Regards Nigel
« Reply #3 on: 05 Aug 2018 at 22:32 »
Nigel,
I can supply pictures of some of those parts from my 1936 Aero 600 if you need them for identification, but I don't have any spares.
[fix typo. 06Aug18 -Doug]
« Last Edit: 06 Aug 2018 at 20:44 by Doug »
Offline nigeld
« Reply #4 on: 06 Aug 2018 at 07:14 »
Hi Doug.. If no trouble some pics of the handle bar mounting brackets from different angles and a ruler next to them for size reference would be great.. many thanks Nigel
« Reply #5 on: 06 Aug 2018 at 22:04 »
Nigel,
I think Douglas introduced these handlebar clamps with the 1934 heavyweight models. There were only two variants, one for one inch handlebars, and one for 7/8 inch bars as used on the 1936 Aero onward. Otherwise they were identical. The center section is an machined aluminum casting. The two end saddles are steel.
[Additional info added.  07Aug18 -Doug]
« Last Edit: 07 Aug 2018 at 17:33 by Doug »
Offline nigeld
« Reply #6 on: 06 Aug 2018 at 22:45 »
Hi Doug.. Thanks heaps the pictures.. Perfect .. have a great day .. cheers Nigel
