For Douglas enthusiasts worldwide since 2004
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Help
Search
Login
Register
Douglasmotorcycles.net
General
Douglas Motorcycle Discussion
Metal spraying
« previous
next »
Print
Pages:
1
Author
Topic: Metal spraying (Read 2535 times)
hartleys1
Full Member
Metal spraying
on:
01 Aug 2018 at 07:12 »
Can anyone help I am trying to locate someone in the UK who can resurface my Ew steel brake drums they are non detachable from the hubs.
I can supply a mandrel for grinding or turning. Unfortunately Metalizers in Heckmondwike as closed down.
Hope you can help Keith Hartley
Logged
dalgrae
Full Member
Re: Metal spraying
Reply #1 on:
03 Aug 2018 at 06:37 »
Try Bristol metal spraying Coronation Road Bristol
Regards. Colin
Logged
eddie
Master Member
Re: Metal spraying
Reply #2 on:
03 Aug 2018 at 07:50 »
Be careful how much you heat up the drum - some rear sprockets were soldered onto the drum!
Logged
hartleys1
Full Member
Re: Metal spraying
Reply #3 on:
03 Aug 2018 at 15:25 »
Hi
Contacted Bristol Metal Spraying they were very help full ,they will do one off jobs but not brake drums
apparently the braking action can strip the metal sprayed from the drum. Plus as Eddie
remarked the heat transfer is greater than the light weight drum will take. Thanks any way
Keith Hartley
Logged
Rex
Full Member
Re: Metal spraying
Reply #4 on:
04 Aug 2018 at 12:37 »
Couldn't you have the drum turned and a steel sleeve inserted to bring it back to standard size?
Logged
eddie
Master Member
Re: Metal spraying
Reply #5 on:
04 Aug 2018 at 15:27 »
As the drum is only about 4mm thick, the sleeve would have to be very thin, and I wouldn't like to have to trust it to stay in place under the braking forces - especially as the heating and cooling could cause it to contract.
Logged
Rex
Full Member
Re: Metal spraying
Reply #6 on:
04 Aug 2018 at 21:39 »
I guess that's a no, then.
Logged
Print
Pages:
1
« previous
next »
General
Metal spraying
