Gord,
The same brake arm shaft was used on nearly all models to 1938. The lever arm did change slightly; over time it became more robust. Initially the front and rear arms were identical, and then the rear was often made with a joggle to suit the model. The spline is identical to the camshaft drive of the DT.
