Author Topic: dirt tracker frame  (Read 2879 times)
Offline carl denton
dirt tracker frame
« on: 14 Jul 2018 at 09:45 »
hi just picked up a dirt tracker frame and motor I know they are both from dirent years but not 100% sure what year I think the frame is 1930.
frame no 10222 eng EL 469 ? any ideas .
thank all
Re: dirt tracker frame
« Reply #1 on: 14 Jul 2018 at 11:35 »
Carl,
        Engine number EL469 features in the LDMCC machine register, and was, at one time, in frame number TF356. It is listed as a 1928 SW5.
 All frames had a TF prefix and only had a maximum of 4 digits.
  Hope this helps,
Offline carl denton
« Reply #2 on: 15 Jul 2018 at 02:21 »
that is interesting Edie I purchased the frame and engine from the son of a gentleman that passed away about 20 years ago and had not moved in all that time . there is a lot of rust on the frame and the only number I could find was 10222 will get the frame blasted and see what I can find thanks so much .
« Reply #3 on: 15 Jul 2018 at 06:25 »
Carl,
        The frame number should be stamped on the left hand side of the gearbox mounting lug, roughly in line with the frame top tube.
