Author Topic: Hand operated oil pump needed  (Read 883 times)
Offline OCTypeCanada
« on: 16 May 2018 at 15:36 »
Does anyone have available to sell a hand operated oil pump to fit into the tank on my 1926 OC type?  The pump screws into a 1 and 1/16 diameter female receptor on the tank and the maximum depth from the top of threads to bottom of tank is 7 and 1/8 inches.
Thanks, Gord
Re: Hand operated oil pump needed
« Reply #1 on: 26 May 2018 at 01:46 »
I am still in search of a hand operated oil pump to fit my OC type.  Pictures of the right part or pumps parts you can sell are most welcome!  I think the pump was common to Douglas bikes around 1926 of age.
Gord
« Reply #2 on: 26 May 2018 at 05:59 »
Hi
Do a search of this forum. Some time ago I posted a set of drawings sufficient to enable manufacture of the oil pump together with detailed descriptions of its functions. Chris
P.S. look under Manual Oil Pump posted in 2004.
« Last Edit: 26 May 2018 at 07:51 by Chris »
« Reply #3 on: 26 May 2018 at 22:05 »
Thank you Chris, I found your article and diagram.
Gord
