Author Topic: eic magnito  (Read 2375 times)
Offline runmark
eic magnito
« on: 13 Apr 2018 at 23:27 »
Hello,  My eic a2 magnito needs rebuilding.  Any leads on a shop to do this.  Thanks, Mark
Offline OCTypeCanada
Re: eic magnito
« Reply #1 on: 14 Apr 2018 at 00:38 »
Offline Eric S
Re: eic magnito
« Reply #2 on: 14 Apr 2018 at 07:25 »
I had a contact with www.dynamoregulatorconversions.com.
He quoted 12 weeks and 400£
Offline Eric S
Re: eic magnito
« Reply #3 on: 16 Apr 2018 at 16:55 »
Steve Belanger at Mainly Magnetos said : We don’t work on them anymore
He advised Jack Kirkland at Automotive Electric in Michigan, 500amp@gmail.com : He says "Have no repair parts in stock for the generators used
on Douglas"
Steve Belanger also advised Kurt at Auto Electric Services in New Hampshire. 603-642-5990.
Did not called him.
All 3 of them are in the USA.
Hope this helps.
« Last Edit: 20 Apr 2018 at 21:31 by Eric S »
Offline Eric S
Re: eic magnito
« Reply #4 on: 20 Apr 2018 at 21:31 »
Runmark
do you made any progress here?
Eric
Offline runmark
Re: eic magnito
« Reply #5 on: 28 Apr 2018 at 23:14 »
No progress so far.  Front cylinder fires fine. rear not so good.
Offline Robert
Re: eic magnito
« Reply #6 on: 19 Jul 2018 at 05:13 »
have you cleaned the slip ring and checked carbon pickups, it may have a carbon buildup causing it to try and fire bath plugs resulting in very week and retarded spark.
Re: eic magnito
« Reply #7 on: 20 Jul 2018 at 01:34 »
I have also found that the points may be opening differently due many factors. From memory its easy to shim the ramps on the EIC to even them up. That can cause what you are talking about
