Author Topic: MK5 Gearbox  (Read 1925 times)
Offline digcot65
MK5 Gearbox
« on: 17 Mar 2018 at 12:25 »
Starting to check everything over ,I removed the dip- stick on the gearbox and the oil was quite emulsified How do you drain the gearbox, what oil is it and how much.Also I may as well replace the engine oil,again what oil and how much Len
Offline digcot65
Re: MK5 Gearbox
« Reply #1 on: 17 Mar 2018 at 14:38 »
I have just read, that there should be a dip -stick on the oil filler cap and it can be knocked of due to poor design.Mine has no dip stick on it.So I need to drain the oil and fill to the correct amount Len
Offline douglas1947
Re: MK5 Gearbox
« Reply #2 on: 17 Mar 2018 at 17:28 »
Len,
I use W50 monograde  engine oil for the gearbox.
Offline digcot65
Re: MK5 Gearbox
« Reply #3 on: 19 Mar 2018 at 11:40 »
Where is the drain plug for the gearbox Len
Offline digcot65
Re: MK5 Gearbox
« Reply #4 on: 19 Mar 2018 at 12:37 »
I have just found the drain plug, but out of my large range of spanners and sockets, I had a job to find the right one.All that comes out of the gearbox is a white emulsified goo.Len
Re: MK5 Gearbox
« Reply #5 on: 19 Mar 2018 at 13:15 »
Sounds like someone has used a pressure washer on the bike and forced water into where it shouldn't be!
