Author Topic: E29 main drive bearing size  (Read 2358 times)
Offline GlenDouglas
« on: 12 Feb 2018 at 06:37 »
Hi all hope someone can help, trying to find correct bearing size for main drive bearing on E29.
Looking at using 4206-BB-TVH   30 id,  62 od, 20 depth.
Many thanks
Re: E29 main drive bearing size
« Reply #1 on: 12 Feb 2018 at 07:28 »
Hi Glen,
            Douglas engines of that period were fitted with a bearing 21mm wide (which is now not available). The recommended replacement is a 62 x 30 x 20mm wide double row rigid bearing (as used on postwar models) with a 1mm shim between it and the bearing housing (putting the bearing hard against the shoulder on the crankshaft).
Offline douglas1947
« Reply #2 on: 12 Feb 2018 at 15:57 »
It is right what eddie is writing.
The bearing 4206 is easy to get.
I think about using a 4206 also in a H3 engine, the engine had 2 of 30x62x10 on drive side, but I think it is better to use a double row bearing.
On timing side was a 25x60x12 (98305) bearing fitted, has the E29 also the same size?
Offline GlenDouglas
« Reply #3 on: 12 Feb 2018 at 20:37 »
Gents thank you, need to make sure use the shim :)
Offline Rojab
