douglas greyhound 1933 kickstarter spring
Started by MJP, 29 Jan 2018 at 19:40
MJP
Hi Guys
im working on a douglas greyhound 1933.
first time on a douglas so all new to me!
the problem:
seems that our kickstart lever refuses to return in position after kicking.
And when I opened the box, there was no spring present.
does anyone have a pictuere of the spring ?
Would be great!!!
Thanks!
The LDMCC Spares Department listed these at one time. There was a 3-speed and 4-speed return spring listed. Both look similar and were a clockwork type spring, but apparently there is some minor difference between the two. The Greyhound could be had with a 3- or a 4-speed gearbox.
