Support & How to Join
Side Panel Notices
Today at 01:04:34
Welcome to the new site!
MK V engine number query
Started by Jonathan Hewitt, 29 Aug 2017 at 18:56
Jonathan Hewitt
Good evening all ,
                I have just bought a Mk V with engine no ' 8944SH ' is this engine right for a  MKV and what does the 'SH' signify please ?
Jonathan
eddie
Jonathan,
               Are you sure that engine number is correct? Could it possibly be 8944 S4? - in which case it would be a Mark 4 Sports engine (possibly with the hotter 'S' cams).
Jonathan Hewitt
Morning Eddie,
             most definitely an    ' H '
Jonathan
Jonathan Hewitt
should be an engine no attached
douglas1947
Jonathan,
the engine number is very unusal.
I send you  the photo of my MK4 engine number to have a look.
eddie
Jonathan,
               Looking at the style of your engine number in comparison to that on Michael's engine, it appears to be in a different font/ size to that used by the factory. Your number (8944) comes very late in the Mark 4 series - not Mark 5. Maybe your engine is a replacement and has been restamped by a previous owner to match the original. Mark 4 and 5 engines were identical (only being distinguished by the suffix to the number) - earlier crankcases were outwardly the same but had detail differences internally.
Pensioner73
Looks as though the original has been ground off, the casing is flattened under the SH number.
Reg
Jonathan,
               I can confirm from the original postwar Douglas factory despatch records that machine with number 8944 was a Mark 4 Sports model sent to BELL and McCANDLESS of BELFAST on 31/8/1950. Bell and McCandless I believe were well known dealers with a particular interest in Nortons and possibly involved in the development of the 'featherbed frame' for Norton. I'm sure other forum users can fill in the details. Knowing this, did they have a play-a-bout with the engine themselves and changed the engine number details?
Reg
Pensioner73
What numbers do the gearbox and frame have?
Jonathan Hewitt
Good evening and thanks, all,
    I have looked at the casting around the number area and it is not nice and round as the 'Douglas ' finish but is indeed flattened off. There is no gearbox number but I do need to look at another box to see and feel any differences.
Frame no is 11355
  Jonathan
eddie
Jonathan,
               A Mark 5 with the frame number 11355 first appeared in the LDMCC machine register in 2001. At that time, it already had engine number 8944 - so your engine and frame have been paired up for at least 16 years. It is a puzzle as to why your engine number has been restamped, as it doesn't match your frame number, and it's original frame (8944) apparently no longer exists.
douglas1947
There is also a 2nd number on the MK engines in front of the oil filler cap. Is this an assembly number of engine builder?
Are these numbers also noticed in the factory despatch records?
Reg
Michael,
I have no idea what the number near the oil filler cap signifies. The despatch records record only the engine number, the dealer/agent it was sent to, and date of despatch. The exception to this is with the early Plus 90 machines with the engine prefix 'X90/xx' . Unfortunately these numbers have not been recorded. In these cases the frame number may(?) be the official record.
Reg
eddie
Reg,
        Do you think that number could be an engine identification number used in the factory prior to the engine being installed in the frame and stamped with a matching number? - just a thought!
douglas1947
It was just a thought.
Panther bikes have not only the engine number, but also a builders number (with a prefix).
Pensioner73
Could it be a part number stamped on because it is slightly different in some way to the standard part. Somebody dropped a little clanger in manufacture.
