Author Topic: Paint  (Read 2518 times)
Offline phil1
Paint
« on: 04 Aug 2017 at 17:38 »
Hi Douglas friends, am looking for Mark v blue spray paint, and not sure if metallic or from memory a flat colour is the way to go? Any suggestions would be very much appreciated. Phil 1 .
Offline tck
    • old racer
Re: Paint
« Reply #1 on: 05 Aug 2017 at 11:47 »
Not a lot of polycromatic blue around nowadays!
Have you searched this forum?
Offline Red
Re: Paint
« Reply #2 on: 05 Aug 2017 at 18:24 »
Hi Phil
Attached is a copy of the invoice from my local paint supplier for the paint I used on my Mark 5. Also attached is a photo of the bike. I was pleased with the colour match, although other members may have other ideas.
Roy
Offline Red
Re: Paint
« Reply #3 on: 06 Aug 2017 at 07:18 »
Hi Phil
Once you have found a paint supplier to supply the base colour coat, use the company detailed in the attached pdf for all your other needs, lacquer, primer masking tape, tack rags etc. Good quality products at a sensible price. The standard lacquer they provide is petrol resistant up to a point - OK for for everything apart from the petrol tank, but they do a more expensive lacquer which is petrol proof. This is shown on the invoice as PRO XL Pro Clear Lacquer at £8.99.
Roy.
« Last Edit: 09 Aug 2017 at 09:35 by Red »
