Author Topic: Misfire at high speed on mk 1  (Read 9026 times)
Offline trevorp
« on: 27 Jun 2005 at 14:16 »
had an interesting problem with a mk 1 engine running a mn1 magdyno
could not get engine to run properly after checking carbies etc
what i found was the points and drive fitted seem to be from something else
i have pictures as i was so baffled i pulled out my points as my bike was running well and compared the two have a look at where the keyways are placed on both units the one on the left is the correct one for a mk douglas
and the shoe size is smaller
life lesson number 1 not everything u get on your bike is origanal lol
Larger view here
Larger view here
Offline tck
    • old racer
Re: Misfire at high speed on mk 1
« Reply #1 on: 23 May 2007 at 15:01 »
Looks like a Vellocette unit to me
Online eddie
« Reply #2 on: 23 May 2007 at 16:10 »
Hi trev,
             It looks as if you have one points assy from a Lucas mag and the other  from a BTH.
                       regards,
Offline trevorp
« Reply #3 on: 24 May 2007 at 07:38 »
no eddie was correct bth and wrong direction
