Author Topic: 90+  (Read 5995 times)
Offline gmt408
90+
« on: 15 Sep 2016 at 13:22 »
Anyone know what these bolt are for on the timing case
90+
T35s
6.0lt XJS
escort mk6 cabrio
Offline oil baron
Re: 90+
« Reply #1 on: 15 Sep 2016 at 20:03 »
Hi There
This looks like the 90+ that is on display at Sammy Millers Museum.  If so I am pretty sure this is the one has been modified in the past to have chain driven camshafts, for some reason that is beyond me, maybe it had shed some teeth of a cam wheel and rather than replace them, they opted for a different solution, I don't know. The 4 bolts in the cover maybe for mounting some sort of a chain tensioning device.
May be contact the Museum to find out a bit more of the history.
Cheers Steve.L
Steve L
Offline David Lawrence
Re: 90+
« Reply #2 on: 16 Oct 2016 at 09:52 »
GMT 408.
The bolts on the timing chest hold oil baffles, they are fairly large castings, Len Boydell has supplied some photo's of a cover he has. If I can attach a couple it clearly shows that they must have been original works efforts, typical Douglas Casting, twice as heavy as required!!
Apologies everybody I seem to have misplaced the pictures but will publish them as soon as they come to light!! :oops: :oops:
Hi Steve,
The plus that had the modified front case is no longer at Sammy Miller's museum, unless it is hidden away somewhere in the backroom we have lost trace of it. The one that is now on display Sammy acquired from a long standing Club member a few years ago.
Re: 90+
« Reply #3 on: 19 Oct 2016 at 21:49 »
GMT 408.
Sorry about the delay I have finally managed to get my act together please find attached three photographs of the inside of a plus cover with the oil deflectors still in place. Len and I hope you find them interesting.
Offline oil baron
Re: 90+
« Reply #4 on: 22 Oct 2016 at 04:02 »
Those baffle things look like they were built with a army tank in mind, I bet even in alloy they weigh quite a bit.  I am puzzled as why go to all that trouble when a sheet alloy baffle could be made do a satisfactory job of baffling oil or did they have another purpose, any ideas?
SteveL
Steve L
Re: 90+
« Reply #5 on: 22 Oct 2016 at 04:12 »
Douglas were founders...
Offline douglas1947
Re: 90+
« Reply #6 on: 29 Jan 2017 at 14:40 »
Interesting details!
Is your bike equiped with alloy barrels and heads?
