2024-06-08, 19:30:04
For Sale
2024-06-07, 03:13:36
2024-06-03, 09:23:05
For Sale
2024-06-02, 09:34:05
Parts avalable
2024-06-01, 19:33:27
2024-05-28, 01:09:46
Welcome to the new site!
26 ew - oil pump worm nut
Started by kev, 10 Sep 2016 at 13:09
kev
  need some advice  1926 EW
   the oil pump worn nut...what holds it on??  or better,  what keeps it from unscrewing??
    does it need a sheet metal tab washer ??
looks like it should be a left hand thread
I have made a new oil pump worm...the original was just a rusty lump..
The worm/nut threads on. It ought to be a LH thread to be 'self-tightening', but it is in fact RH.
The parts list calls out a lock washer (#9120) but they do not say what type it is. My EW came in a bits from many sources, so I do not know that I have one of those, but a tab washer would make the most sense.
There are two types of worm and worm gear. A fine pitch initially used that was prone to stripping the teeth, and a later, coarser pitch.
kev
doug
thanks heaps for the reply....  my original had one side ground off ...I assumed for a tab washer... I,ll make one of those...
   my worm was just a rusty lump...  I made new,  with a 10 pitch...worked out well  I then cut a 24 tooth pinion to mesh...that worked terrible..
   then made another worm the same  a 10 pitch...out of 4130 and used that to cut a helical gear...  that 10 pitch worm cut a nice helical gear ...with 26 teeth...it works real smoooooth
  I couldn't get my setup rigid enough ..so could only cut a bronze gear...after the aluminium prototypes
now just need to know how to time these cams
