Author Topic: Exhaust pipes for a MK3 with waffle box  (Read 1933 times)
Offline terry mortimer
« on: 25 Aug 2016 at 14:15 »
Where can I obtain the short exhaust pipes for my MK3. Also what holds them in secure place if there are no crash bars fitted. I cannot see any fixings or where they could be bolted or have sleeves fitted.
Re: Exhaust pipes for a MK3 with waffle box
« Reply #1 on: 25 Aug 2016 at 15:53 »
Terry,
         You could try Armours in Bournemouth - they used to stock them. With regard to the fixings - your frame should have 2 small lugs on the outside of the bottom rails, directly in line with the engine mounting bolt, to pickup with the mounting bosses on the pipes (the lugs that the crashbars also bolt to).
« Reply #2 on: 25 Aug 2016 at 17:38 »
Thanks Eddie the knowledge you have on Douglas Motorcycles is overwhelming, again many thanks Terry.
Offline dalgrae
« Reply #3 on: 26 Aug 2016 at 16:09 »
I also think that Feked stock them
Regards. Colin
