Author Topic: Modifying mudguard  (Read 2105 times)
Offline ste
Modifying mudguard
« on: 19 Aug 2016 at 10:20 »
Hi, does anyone know how to put the indentation into the rear mudguard (1924 TS) to allow the drive belt to pass? I have a local engineer that wants to cut my lovely new mudguard and weld in a piece. I thought it would just be a matter of applying heat and bending, but I guess you need to make a former pattern for that. Not being an engineer, can anyone advise me please? I've attached a photo of a friends original guard.
Stephen
Re: Modifying mudguard
« Reply #1 on: 20 Aug 2016 at 02:57 »
Hi Stephen,
The steel used in guards is usually quite amenable to reshaping cold. No need for heat or welding.
I spend hours making wooden blocks to suit the inside and outside profile of the guard. MDF works fine, and a jigsaw or a bandsaw is useful. Make a "stack" of these patterns, then relieve the inner patterns in the place where you want to indent the guard. Also cut off the outside part of the pattern in this region. Clamp the whole thing around your guard so that the guard is fully supported in the places on either side of the place where the indent is required. I usually end up with the MDF clamped in the vice. Now get a piece of wood to fit in the gap, with slightly rounded edges, and give it a whack with a big hammer.
I've done it lots of times with good results.
Good luck.
