Hi Alan,
Unfortunately the stuff we play with is old.
Ideally the bearings would be a light interference fit in the cases, and are put in place with the cases warmed first in the oven. To make this work, the inner diameter of the bearing should be size-for-size with the shafts, which should be round and clean.
In the real world... if you have an experience engine builder in your local club, drop in with the bits and have a chat. Oh, and Loctite bearing mount comes in different grades and works well provided the surfaces are properly cleaned. But it won't work miracles!
