Author Topic: Mark V Kick Stand spring location  (Read 1130 times)
Offline steveL
« on: 18 Aug 2016 at 18:58 »
Spurred on by my success with the brake drum, Ive turned my attention to the kick Stand.
I can see the spring location on the Kick stand, but two questions
(I) Where does the other end of the spring locate to - The battery carrier bolt ?
(ii) How long does the spring need to be (Un-stretched) - I measure it at about 6" to the battery carrier bolt (with the stand down) ?
Thanks in advance to all the knowledgeable Mark V owners out there.
Steve
Offline giz.neal
Re: Mark V Kick Stand spring location
« Reply #1 on: 19 Aug 2016 at 09:43 »
Steve,
The spring should locate on a tab welded to the battery carrier, not very secure! If you can contrive a fixing using one of the bottom mounting bolts it will perform reliably. The springs are available from the club spares scheme. All the best.
Giz
Offline steveL
« Reply #2 on: 19 Aug 2016 at 09:51 »
Thanks Giz,
That makes a bit more sense than what I was thinking of!
I hadnt put the battery carrier on yet, so hadn't appreciated that subtlety.
Steve.
