Author Topic: Lugs on TS Frame for Pump for inflating tyres  (Read 2464 times)
Offline Jim47
« on: 29 Jul 2016 at 09:31 »
I am currently building a TS/1924 from parts.  I have a good frame with lugs brazed on to the tube below the top tube to which the fuel tank is attached.  The lugs are for the purpose of holding a hand pump for inflating tyres and the lugs look to be original fittings.  Other TS frames I have seen do not have these fittings for the pump.  As far as I can determine the frame has the same dimensions as a "standard" TS frame.  Could someone please advise me if the frame with lugs is TS, or is it for a different belt drive model?
Thank you
Jim47
« Last Edit: 30 Jul 2016 at 07:30 by Dave »
Offline Dave
Re: Lugs on TS Frame for Pump for inflating tyres
« Reply #1 on: 30 Jul 2016 at 07:31 »
Photo added.
Offline carl denton
« Reply #2 on: 30 Jul 2016 at 13:34 »
hi
they can have the fitting on the frame , or they can have them on the tank . I think they moved them to the tank in 1925 ish .
yours carl
Offline Jim47
« Reply #3 on: 31 Jul 2016 at 05:53 »
Thanks Carl, I'll use this frame as planned.  Also, you have answered another question: why some tanks have fittings and others don't.
Regards Jim47.
