Author Topic: Side Stand  (Read 2261 times)
Offline Christo
Side Stand
« on: 25 Jul 2016 at 18:28 »
Hi Folks,
Has anyone else had problems re no side stand - cos for the life of me I just can't manage that ridicules centre stand! I hope somebody has sorted the design of the side stand and would be willing to make another?
Christo, North bucks
1952 Mk5
Re: Side Stand
« Reply #1 on: 25 Jul 2016 at 21:14 »
Hi Christo,
                The fact you are having trouble managing the centre stand begs the question - 'Has your bike got a stand retaining clip fitted to the front end of the rear mudguard?' This clip not only keeps the stand in the raised position but also provides a halfway position that allows you to shift your foot from the pad to the bottom of the stand (making raising the bike onto the stand much easier).
Offline Red
Re: Side Stand
« Reply #2 on: 26 Jul 2016 at 15:20 »
Hi Chris
Eddie is right about the stand clip. He pointed out that my Mark 5 had no stand clip, but even now this is fitted I still find the centre stand difficult to use. As a result I made up and fitted a side stand which is so much easier to use. Have a look at the link below. Roy
https://www.douglasmotorcycles.net/index.php?topic=5892.0
Offline tck
    • old racer
Re: Side Stand
« Reply #3 on: 26 Jul 2016 at 19:22 »
I fitted one using the main engine through bolt and running a loop bracket around the exhaust pipe LH side of course then attached a prop stand to that keeps the stand in line with the main mass of the engine
