Author Topic: EW350 Parts Manual Availibility  (Read 4441 times)
Offline nicos
« on: 19 Jul 2016 at 23:04 »
G'day, I've just started restoring a basket case 1927 EW 350 and would also like to know if there is an illustrated list of parts with drawings as I will have to make some hard to find parts.
 I have a copy of the factory 1927 manual but it only gives a description of the components.
As I have to replace some of the frame tubes a frame drawing with specifications would be most helpful. I'd appreciate any help.
Kind regards
Mal form Brisbane
[re-title split topic. 20Jul16 Doug, Site Moderator]
« Last Edit: 20 Jul 2016 at 23:23 by Doug »
« Reply #1 on: 20 Jul 2016 at 16:13 »
Nicos,
Unfortunately for the 350EW model, there was never an illustrated version of the spares list. Or none that I have ever come across in the last thirty years. They did one for the 600EW, but not a lot transfers over to the smaller model.
As for the frame, you will have to ask fellow 350EW owners for specific dimensions. I do have a '27 350EW that is in a practically bare-frame state right now (though in storage), so could probably pull some dimensions given time.
[split topic to separate post. 20Jul16 Doug]
« Last Edit: 20 Jul 2016 at 23:22 by Doug »
Offline nicos
« Reply #2 on: 20 Jul 2016 at 23:06 »
Thanks Doug
                     I'll take my ruler, calipers and tape to another EW owner and do the measurements.
Offline Alan Cun
Re: EW350 Parts Manual Availibility
« Reply #3 on: 22 Jul 2016 at 09:23 »
Hello Mal,
Before you get too carried away with your frame repairs I have some incomplete and damaged frames that I cant see me using in the future. I dont have any spare brake drums or backing plates. They are always the hardest bits to find. The backing plates are easily cast. I would need to know what gearbox you would be using. The early version has slots on the frame mounting and later just sit on round tube with a four hole plate under.
regards Alan
Offline nicos
« Reply #4 on: 22 Jul 2016 at 23:22 »
Thanks very much for your offer Alan, I'll give you a call.
Mal
