Author Topic: How not to do it! - finding floatchambers for Amac on my 2 3/4 HP  (Read 13298 times)
Offline pvn06
Although my 2 3/4HP restoration basket case looks to have the correct early Amac carb (notice it has a clamp style fixing to the inlet manifold, which I think is correct for a 'teens  2 3/4), it's float chamber had been fitted with a later Amal small diameter float chamber cap.  Therefore, for the last month or so I had been keeping a careful vigil on ebay.  Added to this, my own Amac carb float chamber was missing the internal float and float needle.
About 3 weeks ago I spotted a very nice condition Amac float chamber and was (as normal) sat there poised in the last 10 seconds of the auction and was successful in winning it.  When it arrived I was over the moon - as it was in even better condition than the ebay photos indicated.  However, once out in the workshop, the situation did not look so rosy - the float chamber was slightly bigger than the Douglas version, the cap would not fit, the float would not fit in and the mount to the main carb was different - with the original Douglas type having a flange and an internal taper that the bigger float chamber did not have!
Just goes to show how easy it is to get caught out . . . I though it looked pretty close in the photos, shows what I know!
Anyway, as it was so nice, initially I thought I might do my normal bit - and make it fit! (i.e. machine the mounting to fit the earlier carb) - but within a day or so I found myself running my normal search trawl's on Ebay and was very surprised to within a week or so find the float chamber you see in the accompanying photos.  There was not too much interest until the last few seconds (that's not unusual though on ebay) - but as a coincidence I ended up in small last seconds battle and paid almost exactly the same amount as the other one.  However, in this case I seem to have got it right - as this one is the same type as my original - but has a complete and good condition Amac floatchamber top and tickler, as well as the float and float needle inside.
Again, on arrival it was a quick visit to the workshop, but this time I was not disappointed and it is a perfect fit.
Although a little bit wiser (or as Churchill would have said - not wiser, but better informed!) I am not disappointed by having paid twice the amount I intended - I have learnt a bit from it . . . and my spare engine is fitted with a later small bore Amal.  As I was considering for the future working out how to turn this SV into a replica of the first pre-Kaiser OHV, a slightly bigger Amac may be a consideration . . . and also it is very pretty!
As a final point of interest - while photographing the original Amac fitted to my bike for this article, I noticed traces of dark army green paint on the body and original floatchamber - leading me to believe the carb and inlet tract may be from a WW1 WD bike . . . what a lovely little time capsule!
More soon,
Paul
www.racingvincent.co.uk
Offline pvn06
and now photos:
Offline pvn06
and a few more:
Hi Paul,
Welcome to the world of (truly) vintage motorcycles!
By chance I spent yesterday afternoon in the shed sorting out my box of AMAC carburettors, and I can confirm that there are many different fittings for the flat-chamber connection (four I can think of), as well as different float bowl sizes. The earliest AMAC I have is a 1909 model (on my water-cooled Lewis), and the merger with B&B and Binks to form AMAL occurred, rather gradually, in the period 1928-1930. Plenty of traps for the unwary over 20 years of AMAC carbies.
Before I get bombarded, the AMAC box has been drained dry of 2 3/4 Douglas carbs. However there is one very small AMAC float bowl, but to my eye it looks even smaller than required by Douglas. It might be veteran Douglas - perhaps the first year of the AMAC, 1913?
The carby on the engine looks to have been fitted with the tickler from an Amal Monobloc carb!
Offline pvn06
Hi Leon,
Yes - always learning . . . that is what I love about working on old bikes, as you move into a new area you find out new things and you start to unravel a little bit about that period of time . . . I am starting to learn a little bit more about Amac's now!
I will leave the carb's there for now - I will come back and strip the very original looking main body sometime in the future  . . . and no doubt will find all things I need to do and learn then!  Incidentally . . . I have a tin of very early Amal jets and bits (from my old friend Titch Allen), which I have always thought of as - from old carbs that are older than I will ever need or own (most of my rare carbs are racing TT's/RN's or similar from the 30's-50's) - but having revisited that tin recently  . . . I have found it is still too modern for the Douglas! (probably late '20s)
Moving on . . .
Paul
www.RacingVincent.co.uk
ps - thanks as well Eddie, although now you have taken the edge off! . . . now you mention it, that tickler does look like a later one .  .. perhaps I will just have to machine a proper looking one! (shall have to find a photo somewhere)
I found these photos on my computer, showing a "typical" veteran Douglas-AMAC (with the exhaust-gas heater), and a "typical" 1920s model. AMAC literature suggests that the veteran version would have been current c1914-1919, replaced by the later type 1920-1925. There were variations on each pattern.
The method of attachment of the fuel bowl is one of the points of difference.
Offline Domas
Done.
« Last Edit: 10 Aug 2019 at 11:00 by Domas »
