Author Topic: Mk5 twist grip supplier  (Read 2040 times)
Offline dalgrae
« on: 24 May 2016 at 17:25 »
Can someone possibly advise me regarding the original supplier for both grips on a MK 5 and what sort of pattern they were ,mine   are well past their best but I can see they are marked with the brand name Dare .
regards  Colin
Offline Dougiethenoo
Re: Mk5 twist grip supplier
« Reply #1 on: 26 May 2016 at 20:16 »
I would guess the original was Amal - you could spring for this:
http://amalcarb.co.uk/controls-cables/twist-grips/type-16-single-cable-twist-grip-7-8-bars.html
I've replaced the badly corroded twist grip and the rubber hand grips on my Mk3 with this pair - much cheaper reproduction quality - but they work fine.
https://www.feked.com/standard-twistgrip-7-8.html
Hope this helps.
Offline dalgrae
« Reply #2 on: 27 May 2016 at 06:18 »
Hi thanks for the reply ,the twist grip is OK so I will order a set of the Amal rubbers
regards  Colin
