Advertisement
Advertisement
pressing clutch part
Started by kev, 19 May 2016 at 09:25
kev
26 ew clutch
  on sunday I made up a press die to make the sheet metal flange that goes around the springs...
having some trouble as the metal I was using would split just as I reached the final shape..
one of the club members suggested maybe I was using ...the wrong type of sheet metal...I was using zincalume  a roofing ducting product...went over to a panel beaters picked up a tailgate off a vw anorak...
yeah...what a big difference...working very well...just need to make some trimming dies..
and another dougy part is in unlimited supply
can any body tell me the thickness of the spring pressure plate...on the outer of the flywheel...might have another go at that die...
kev
had the missus come in and rename the file...
get these pictures in...
Glenn Mckenzie
Daren W Australia
Hi working in the motor trade cutting out holes to put sunroofs in for 29 years the softest roof metal is Proton and Subaru the stiffest is VW Passat wagon, nice Job done Daren
Advertisement
