Author Topic: ew clutch  (Read 2466 times)
Offline shuswapkev
ew clutch
« on: 02 May 2016 at 14:10 »
  now starting on the clutch side
  here are all the parts I have...what is missing???
 I m sure there is a brass ring with balls , thrust bearing on the clutch throwout arm??   could somebody take a picture and some measures...I have the ball race dia..as there is a track around the clutch arm  1/8 balls???
there must be a thrust  plate on the  clutch side of the thrust bearing..  picture and sizes would help...
the sheet iron plate that is screwed to the back of the flywheel has a flange on the inside...and it is cutting into the clutch fibre...looks like this means the fibre inner dia is too small???
the outside washer with the ears on..has some little flanges...are these necessary??  mine are broken off on one side...about half of it.....
must be something under the springs inside the flywheel???  what does it look like???
and the nut to hold it all on...what does that look like???
the outer plate that holds the springs...what does that look like???
thanks heaps for any help
Offline shuswapkev
Re: ew clutch
« Reply #2 on: 02 May 2016 at 21:37 »
thanks heaps for that doug...
I,ll have a busy night going thru that
